Applicable Model
This information is for the following model(s):
- ILCE-6700
- ILCE-6700K
- ILCE-6700L
- ILCE-6700M
About This Download
What to Keep in Mind Before Performing the Update
- You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
- Increases the maximum number of images that can be recorded in one folder to 9,999
- Improves image quality when applying user LUTs
- Displays the Wi-Fi signal strength when the Wi-Fi function is On
- Allows notifications to be displayed when the latest software is available for your camera
- You can now continue shooting while transferring captured photos and videos to a smartphone or tablet
Note:- Ver. 2.9.0 or later of the Creators' App is necessary. This service may not be available in some countries or regions. For more information, please visit the Creators' Cloud support website.
- Transfers to smartphones and tablets can now be resumed if they are interrupted
- You can now transfer only the data that hasn't yet been sent to your smartphone or tablet, or add videos to be transferred during the transfer process
- Allows you to upload camera images directly to the Creators' Cloud
Notes:- Settings must be adjusted in the Creators' App in advance. For more information, please visit the Creators' App support website.
- WPA and WEP functionalities are no longer supported. You will no longer be able to select WPA or WEP when connecting to Wi-Fi. Please use the more secure WPA2 or WPA3 security setting moving forward
- Improves the operational stability of the camera
Note: Please refer to the Help Guide for details on all updated functions.
Previous Benefits and Improvements
View previous benefits and improvementsFile Info
- Name: BODYDATA.DAT
- Version: 2.00
- Size: 1 024 017 848 bytes
- Release Date: 10-06-2025
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version
Follow the instructions below to check the system software version.
- Select Menu → Setup → Setup Option → Version.
- The system software version will be displayed.
Notes:
- If the system software version is Ver. 2.00, the update is not required.
- If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
- Click the Download button.
- After reading the disclaimer, click Download.
- Save the file to your computer.
- Insert the formatted memory card into the computer.
- Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
Notes:
- Please format the memory card in advance using this camera.
- Before formatting, copy the data to a computer or other device.
Once you format the memory card, all the data recorded on the memory card will be deleted and cannot be restored. - Please refer to the instruction manual of the camera for compatible memory cards.
Other Hardware
- Power source for the camera: Fully charged rechargeable battery pack (NP-FZ100).
Note: The update can only be performed when the battery power level is above 51%. We recommend you use a fully charged battery.
Updating the System Software Version
Important Notice
- Use a fully charged rechargeable battery pack (NP-FZ100).
- Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
- It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
Step 1: Update the System Software
- Insert the memory card that contains the saved system software data into slot of the camera.
- Select Software Update.
- Select Execute on the system software update confirmation screen. The software version update will start.
On-screen message:- The Update? X.XX → Y.YY
- X.XX: Current version number
- Y.YY: Newest version number
- Do not remove the battery or memory card during the update.
- After confirming the details, you may click Execute.
- Please scroll down the screen as necessary to view the full text.
- When the system software update starts, a black screen will appear and the access lamp will flash 1 time → 3 times → 5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
Notes:- If the system software data copy is incorrect, the message The target model for the update file is incorrect will be displayed on the camera monitor.
- If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or repeats 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), the system software may have been incorrectly copied to the memory card.
- In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
- When the update is completed, the camera will automatically restart. After restarting, when the Body update complete screen appears, press OK.
Step 2: Confirm the System Software Version of Your Camera.
- Select Menu → Setup → Setup Option → Version → Body.
The update was successful if the screen shows Ver. 2.00.
