Applicable Model
This information is for the following model(s):
- ILCE-7M4
- ILCE-7M4M
About This Download
What to Keep in Mind Before Performing the Update
- Updates should be installed in chronological order. When updating from Ver. 1.01 or earlier, you need to update to Ver. 1.05 first, and then to Ver. 6.01. If you try to install Ver. 6.01 without updating to Ver. 1.05, an error will occur and you will not be able to update your camera.
- This update is only available for memory cards. Windows and macOS versions are not provided.
- You can download the software update using the Creators' App available in the App Store and Google Play.
How to Save Your Settings Before Updating
When updating to this software version, the following settings will be unregistered or reset to their default values:
- Settings for Network Streaming, Cloud Connection, and Access Authen.
- Switch Focus Area and Send to Smartphone registered to Custom Key
- Version registered in My Menu
Note: Even if you previously saved your settings using features such as Save/Load Settings, these settings will not be carried over to cameras with Ver. 6.01 or later. We recommend writing down your settings in advance as needed.
Benefits and Improvements
- Fixes an issue where some products were unable to update to Ver. 6.00, as well as an issue where products that successfully updated to Ver. 6.00 would enter power save mode when the monitor was closed, regardless of the Power Save by Monitor setting. We apologize for any inconvenience this may have caused.
- This update also includes the improvements that were introduced in Ver. 6.00.
Shooting and Playback Functions
- Adapts the display layout of shooting information for both horizontal and vertical viewing
- Adds Spot: XL under Spot in the Focus Area menu
- Adds Custom 1, Custom 2, and Custom 3 under Custom in the Focus Area menu
- Adds Tracking: Spot XL, Tracking: Custom 1, Tracking: Custom 2, and Tracking: Custom 3 under Tracking in the Focus Area menu
- Adds the Golden Ratio Grid option to the Grid Line Type setting menu
- Adds the option to enlarge the menu screen display
- Allows you to add OK/NG/KEEP flags to clips during or after movie recording
- Allows the remaining capacity of both storage devices to be displayed during movie recording when using Simult. or Auto Switch Media (Relay Recording)
- Displays audio levels on the screen at all times during movie recording
- Adds support for the Relay Playback function
- Adds a function that allows you to narrow down played-back images using multiple filters (e.g. Rating)
- Allows Custom Key settings to be assigned to the AF-ON, AEL, and Delete buttons during playback
- Adds support for importing/switching multiple IPTC Presets
- Supports the Write Digital Signature function for movies as part of Sony's Camera Authenticity Solution
- The timing for the provision of licenses (paid) to customers other than certain media outlets is yet to be determined.
- Services may not be available in some countries or regions. For more information, please visit the Authenticity Catalog Page.
- Supports Scan and Tag, Photo Cropping, and Volume Photography Commands under the Volume Photography License
- Installation of a paid license is required for use.
FTP Transfer and Network Functions
- Allows scheduling of FTP transfers while writing data to the camera's storage media
- Allows you to automatically schedule FTP transfers of protected movies and still images
- Allows you to automatically protect movies/still images transferred via FTP transfer
- Allows you to transfer specific images with priority during FTP transfer
- Supports the following Monitor & Control app function:
- Focus map display
Note: The latest version of the Monitor & Control app is necessary. The app may not be available in some countries or regions.
- Focus map display
Others
- Improves the operational stability of the camera
Note: Please refer to the Help Guide for details on all updated functions.
Previous Benefits and Improvements
View previous benefits and improvementsFile Info
- Name: BODYDATA.DAT
- Version: 6.01
- Size: 739 253 656 bytes
- Release Date: 15-01-2026
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
Check the System Software Version
Follow the instructions below to check the system software version.
- Select Menu → Setup → Setup Option → Version → Body.
- The system software version will be displayed.
Notes:
- If the system software version is Ver. 6.01, the update is not required.
- When updating from Ver. 1.01 or earlier, you need to update to Ver. 1.05 first, Please update to Ver. 6.01. If you try to update this version without updating to Ver. 1.05, an error will occur and you will not be able to update the software.
- If the Date/Time setting screen appears when you turn on your camera, be sure to set the date and/or time to the correct values.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
- Click the Download button.
- After reading the disclaimer, click Download.
- Save the file to your computer.
- Insert the formatted memory card into the computer.
- Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
Notes:
- Please format the memory card in advance using this camera.
- Before formatting, copy the data to a computer or other device.
Once you format the memory card, all the data recorded on it will be deleted and cannot be restored. - Please refer to the instruction manual of the camera for compatible memory cards.
Other Hardware
- Power source for the camera: Use a fully charged rechargeable battery pack (NP-FZ100).
Note: The update can only be performed when the battery power level isat least three bars or more. We recommend you use a fully charged battery.
- Detach the vertical grip from the camera before updating the system software.
Updating the System Software Version
Important Notice
- Use a fully charged rechargeable battery pack (NP-FZ100).
- Do not remove the battery during the update as the sudden loss of power may render the camera inoperable.
- It may not be possible to update if the camera temperature is high. Please wait to update until after the temperature drops.
Step 1: Update the System Software
- Insert the memory card that contains the saved system software data into slot 1 of the camera. For models with two slots, make sure to insert the memory card into slot 1. Only slot 1 will recognize the system software data.
- Select Software Update.
- Select Execute on the system software update confirmation screen. The software update will start.
On-screen message:- Update? X.XX → Y.YY
- X.XX: Current version number
- Y.YY: Newest version number
- Do not remove the battery or memory card during the update.
- After confirming the details, you may click Execute.
- Please scroll down the screen as necessary to view the full text.
- When the system software update starts, a black screen will appear and the access lamp will flash 1 time → 3 times → 5 times depending on the progress of the update. The update will take approximately 6 minutes to complete.
Notes:- If the system software data copy is incorrect, the message “The target model for the update file is incorrect” will be displayed on the camera monitor.
- If the access lamp repeats 5 long blinks (0.5-second cycle) and 6 short blinks (0.25-second cycle), or 7 long blinks (0.5-second cycle) and 7 short blinks (0.25-second cycle), it is possible you have not updated from Ver. 1.05, or the system software may have been incorrectly copied to the memory card.
- In this case, remove the battery and memory card from the camera, prepare another memory card, and then start over from the Saving the System Software Data to a Memory Card section of this article.
- When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete” screen.
Step 2: Confirm the System Software Version of Your Camera
The update was successful if the screen shows Ver. 6.01.
